my garbage disposer emits this bad odor and white smoke when i tried to unclog it with the key and pushing the little red button underneath. Does this means capot.? Thanks.
Did you pour any liquid drain cleaner into it?
No, No liquid drain cleaner.
Don't know what that smoke is; but if you can freely turn the motor by hand from below, and it isn't responding to the electric switch--either you have a faulty switch, or the unit needs to be replaced.
