Disposer is leaking from 2 places on bottom which appear holes from fitting inside disposer. Can it be fixed or should we purchase new one?:confused:
I'm having the exact same problem with my Maytag garbage disposer. After thinking it over, I decided just to call a repairman. Biggest problem is not being able to run the dishwasher.
Final outcome: It had to be replaced.
I have a Badger and it is badly leaking from the bottom and it appears from the inside. It just happened tonight as I was running it and a bone may have caught in it. Can a chicken bone really cause that kind of reaction from a 1/2 HP motor?
