Need to know what part to get. I thought that it might be the pump. Water goes in fine and drains out fine, the water doesn't come out of the arms. Before this happen the dishwasher was real noisy.:confused:
Originally Posted by: Spankey  Need to know what part to get. I thought that it might be the pump. Water goes in fine and drains out fine, the water doesn't come out of the arms. Before this happen the dishwasher was real noisy.:confused: Spankey, Sounds like you had something enter the pump and damaged the parts I have listed for you. Impeller Chopper Flapper valve Part number: AP3738238
Part number: AP3152971
Part number: AP3039186
The most likely situation is , You'll need to remove the pump assembly and tear it down and replace the parts as necessary, or order the complete pump assembly. Part number: AP4434612
 That of course would be your decision, but either way it's still cheaper than a new dishwasher. Good Luck, :) :) :)
Thanks for the information. You were very helpful, now for me to think if I can do it.
Originally Posted by: Spankey  Thanks for the information. You were very helpful, now for me to think if I can do it. Spankey, You can do it , It looks worse than it is. Let us know when you're ready and we can try and get you a PDF manual. :cool: :cool: :cool:
