AppliancePartsPros.com
Appliance Repair Help
Washer Repair
How do I remove the control panel when there is no visible screw and no masking ends?
We just moved to a new place and, in three months, the top load Kenmore washer that came with the house gave up. Most likely the direct coupler between the motor and transmission is broken. The most recommended way to replace a direct coupler is by removing the cabinet and get access to the motor area. My problem is that there are no visible screws to remove in order to take out the control panel and then the cabinet. Two questions: 1. How do you remove the control panel on a top load washer when there are no visible screws? I found some instructions online about releasing the clamps from beneath the plastic pieces at both ends of the control panel using a patching knife, but I can't figure out how to do it. 2. Would it be more practical to access the motor area from underneath (by laying the washer on one side) for this type of washers? Thank you.
It's almost always much, much easier to pull the cabinet. There is a console clip (#8 on the diagram) on each side of the console which should be carefully released by inserting a putty knife under the console from the front on each side. Then just follow the instructions attached to the reply. - The motor coupling Part number: AP3963893
Gene, you are the man. Although previously I have found all the information you sent me on other places on the Internet, your email was reassuring and pushed me in the right direction. After finagling for about 15 minutes with the clips that hold in place the control panel, I ended up releasing them and, from that point on, replacing the coupler was a child play - it took me less than 30 min to do the job. Thank you! I have to say that in my opinion all technically inclined minds should make their professional expertise available online and be somehow supported for doing this. I thing that there is a real market for such an initiative. For instance, thru your advice I saved a lot of money and worry and I am willing to share with you a part of what I saved. I am not kidding! So, hopping that this doesn't insult you, please let me know where to send you a check for $20 (send the information in such a way that convinces me it is from you and not a scam so somebody else gets the money). Thanks again and keep up this admirable effort.
Thank you for your good words. Your appreciation is the best reward for all of us helping people like you on this forum.
Washer Repair
