I am trying to replace the inner door shelving on my freezer door. How do I get the gasket and old door shelving off. I can't tell if or where the screws are.
We need your model number to look at the breakdown of your unit. Nat
model number CTX21DIBRRAA
Here is the breakdown of your unit Model CTX21DIBRRAA if you look on page 7 that is your freezer door. There looks to be a horizontal & vertical retainer that hold the gasket on, after those come off you shouldsee the screws to change out the shelves. Hope that helps Nat
