After I replaced the water filter, I was flushing the dispenser as directed and the water stop flowing, I checked to wires leading to the dispenser and there is no power going to them. The ice maker leads have power, and the icemaker works fine. What do you think the problem could be.
Originally Posted by: newhall  After I replaced the water filter, I was flushing the dispenser as directed and the water stop flowing, I checked to wires leading to the dispenser and there is no power going to them. The ice maker leads have power, and the icemaker works fine. What do you think the problem could be. Newhall, I'm thinking, Loose wire connection in the top of the freezer door hinge wire harness. Possibly a bad water dispenser switch or actuator tab on the dispenser paddle, in the dispenser assembly. At this point, that's where I'd start. Good Luck, :cool: :cool: :cool:
We changeds the water inlet valve and all is working now. Thanks
Originally Posted by: newhall  We changeds the water inlet valve and all is working now. Thanks Great, That would have been the next component to check, It was a pleasure to help. Good Luck, :) :) :)
