newhall
#1 Posted : Monday, October 11, 2010 10:42:23 AM(UTC)
newhall
After I replaced the water filter, I was flushing the dispenser as directed and the water stop flowing, I checked to wires leading to the dispenser and there is no power going to them. The ice maker leads have power, and the icemaker works fine. What do you think the problem could be.
#2 Posted : Monday, October 11, 2010 1:56:12 PM(UTC)
Originally Posted by: newhall Go to Quoted Post
...I checked to wires leading to the dispenser and there is no power going to them...
I'm assuming you checked the voltage to the water inlet valve?
Did you keep the freezer door closed while doing this test?
Is the ice cubes dispenser working?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL ED5HHGXTQ00 Refrigerator | AppliancePartsPros.com
Joe / APP Team
#3 Posted : Monday, October 11, 2010 1:58:44 PM(UTC)
Joe / APP Team
Newhall,
I'm thinking,
Loose wire connection in the top of the freezer door hinge wire harness.
Possibly a bad water dispenser switch or actuator tab on the dispenser paddle, in the dispenser assembly.
At this point, that's where I'd start.
Good Luck,
:cool: :cool: :cool:
newhall
#4 Posted : Tuesday, October 12, 2010 4:54:21 PM(UTC)
newhall
We changeds the water inlet valve and all is working now. Thanks
Joe / APP Team
#5 Posted : Wednesday, October 13, 2010 5:34:41 AM(UTC)
Joe / APP Team
Great,
That would have been the next component to check,
It was a pleasure to help.
Good Luck,
