Clothes are not drying:mad: , the barrel works fine it spins open the door and it's steamy inside ( feels hot ) but clothes are still wet. I cleaned the lint hose and everything but still no luck . What could it be :confused: .
Check inside the blower housing around the fan, you may want to clean from the lint screen all the way outside. If you use ddryer sheets a lot you should use a soft brush and hot soapy water to clean it too. Also check your vent pipe to make sure it isn't crimped. Nat
