kmtse
#1 Posted : Tuesday, October 5, 2010 10:30:19 AM(UTC)
kmtse
My 18 year old electric Jenn-Air oven (W130W) was smoking after a popping sound and then the power went off during preheating. Later discovered the lower baking element was melted at one spot. I found the parts for that but was wondering what else needs to be replaced since no power on the display. Is there a thermal cut-off switch or circuit breaker within this oven? or perhaps the control panel is bad (which now no longer available)?
magician59
#2 Posted : Tuesday, October 5, 2010 12:00:27 PM(UTC)
magician59
When the element melted through, it may have (probably did) grounded on the oven liner, and tripped the breaker. [COLOR="Red"]At any rate, go to the breaker and shut it off completely, before attempting to replace the element.[/COLOR] When you turn the breaker back on, you may need to flip it on, off, then on again. Tell us if that solves your display problem.
