454
#1 Posted : Tuesday, October 14, 2008 5:18:04 AM(UTC)
454
Washer will not spin and there is a burning smell, works fine up until that point
libertyappl
#2 Posted : Tuesday, October 14, 2008 6:35:05 AM(UTC)
libertyappl
Check your belts & pulleys to see if one of the "locked" up.
nat
454
#3 Posted : Tuesday, October 14, 2008 7:07:13 AM(UTC)
454
Checked both pullys and they turn freely. Is there anything else I can check?
454
#4 Posted : Tuesday, October 14, 2008 7:10:36 AM(UTC)
454
It finishes the cycle before spin and it tries to go into spin but it doesn't
libertyappl
#5 Posted : Tuesday, October 14, 2008 8:03:04 AM(UTC)
libertyappl
Test your motor & motor switch.
Here's the breakdown of you machine.
Model LAT9206BAE
Nat
454
#6 Posted : Tuesday, October 14, 2008 8:13:09 AM(UTC)
454
How do I test the motor and the switch?
v2k04
#7 Posted : Tuesday, October 14, 2008 8:34:54 AM(UTC)
v2k04
here is how you hotwire a Maytag motor but you could have a siezed up spin bearing causing your problem as well pull the front cover and look at center of tub underneath and see if water is leaking which took out the bearing if it has your probably looking at a new machine attached is the diagram
v2k04 attached the following image(s):
454
#8 Posted : Friday, October 17, 2008 8:37:20 AM(UTC)
454
It ended up being the siezed bearing, water had leaked down on it. Thanks for the help
SPRINT
#9 Posted : Tuesday, January 4, 2011 12:26:40 PM(UTC)
SPRINT
Could we get a little bigger, readable wire diagrahm on this one Thanks.
