jrzfamily
#1 Posted : Monday, October 13, 2008 8:24:45 PM(UTC)
jrzfamily
After use today, my oven started beeping randomly. It took an extra long time to heat up today, longer than usual which is 10-12 minutes to get to 350 degrees.
After the oven was turned off, it would beep then beep 2-3 minutes later, then beep 10-15 times per minute.
No abnormal display or codes.
When the oven is turned on to bake, it runs for a few minutes, starts to get warm, then shuts itself off.
Any thoughts? Thanks
#2 Posted : Tuesday, October 14, 2008 4:12:02 PM(UTC)
Open the control panel and remove the control panel ribbon form the control board. Power up the oven and wait a few hours.
If it'll beep again then the problem is a bad control board which is no longer available but can be rebuilt.
If it'll stop beeping then the problem is a bad control panel which is no longer available too and is not repairable.
