After use today, my oven started beeping randomly. It took an extra long time to heat up today, longer than usual which is 10-12 minutes to get to 350 degrees.
After the oven was turned off, it would beep then beep 2-3 minutes later, then beep 10-15 times per minute.
No abnormal display or codes.
When the oven is turned on to bake, it runs for a few minutes, starts to get warm, then shuts itself off.
Any thoughts? Thanks
Open the control panel and remove the control panel ribbon form the control board. Power up the oven and wait a few hours.
If it'll beep again then the problem is a bad control board which is no longer available but can be rebuilt.
If it'll stop beeping then the problem is a bad control panel which is no longer available too and is not repairable.
