I ran the self clean feature and next day tried to used the oven. It did not heat then tried to check the broiler element it too did not to work. Do these need to be replaced or did something happen when I ran the self cleaner? Everything else is working display/timer/fan.
Thanks, Tami
A model number may help others help you.
Many units have an overheat thermostat that kills power to both elements, perhaps this is shot.
Also try flipping the breaker off/on a couple times, sometimes you can loose half the line without actually tripping the breaker. |
THIS FORUM IS DEAD!!!!!!! |
