tami01
#1 Posted : Thursday, September 30, 2010 6:23:39 AM(UTC)
tami01
I ran the self clean feature and next day tried to used the oven. It did not heat then tried to check the broiler element it too did not to work. Do these need to be replaced or did something happen when I ran the self cleaner? Everything else is working display/timer/fan.
Thanks,
Tami
#2 Posted : Friday, October 1, 2010 2:08:10 AM(UTC)
A model number may help others help you.
Many units have an overheat thermostat that kills power to both elements, perhaps this is shot.
Also try flipping the breaker off/on a couple times, sometimes you can loose half the line without actually tripping the breaker.
Thermador Dual Fuel Oven Element Replacement (Oven Repair (including Ranges and Cooktops))
by andyatthepond 2/2/2011 3:27:48 PM(UTC)
Broiler Upper Oven Element Replacement (Oven Repair (including Ranges and Cooktops))
by Auzzie 10/4/2010 10:29:14 AM(UTC)
thermador oven element replacement (Oven Repair (including Ranges and Cooktops))
by FCarone 9/18/2010 8:09:07 AM(UTC)
by ChadJ 12/21/2009 11:22:08 AM(UTC)
by gloriasaw 11/27/2009 9:05:15 AM(UTC)
Oven element replacement 240v or 250v (Oven Repair (including Ranges and Cooktops))
by yoda@ui 10/10/2009 10:03:47 AM(UTC)
