madcaroler
#1 Posted : Wednesday, September 29, 2010 8:04:53 AM(UTC)
madcaroler
Hello. A mouse chewed the connector from the sensor on the front of the sump, visible behind the kickplate. Sensor had 3 wires going to it; black grey, white. I need to know the order of the 3 wires to make a new connector.
For example... black, white gray (from left to rite)
Thanks!
#2 Posted : Thursday, September 30, 2010 2:26:28 AM(UTC)
I could not find info on your specific unit hopefully the following is a close match.
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
I am assuming you are referring to the soil sensor.
Pin 1 - White
Pin 2 - Black
Pin 3 - Grey
Often pin numbers are marked on the plug body or pin 1 will be marked.
Sorry I could not give you a definitive answer.
madcaroler
#3 Posted : Friday, October 1, 2010 6:31:37 PM(UTC)
madcaroler
Thanks very much. I'll give that a shot and see if it will work properly.
I could measure to determine ground pin.... it shouldn't destroy the sensor if i reverse VCC and Vout.
Will post with the results!
