Hello. A mouse chewed the connector from the sensor on the front of the sump, visible behind the kickplate. Sensor had 3 wires going to it; black grey, white. I need to know the order of the 3 wires to make a new connector.
For example... black, white gray (from left to rite)
Thanks!
THIS FORUM IS DEAD!!!!!!! |
Thanks very much. I'll give that a shot and see if it will work properly.
I could measure to determine ground pin.... it shouldn't destroy the sensor if i reverse VCC and Vout.
Will post with the results!
