Water runs in the washer, then the water stops before the washer is full. There is a humming sound. The wash starts to rinse before it washes. The rinse stops. Nothing else happens. There is a constant humming noise.
Please help me in determining the problem so I can fix it.
Thank you.
the humming sound is the fill valve energizing, calling for water, double check your faucets to make sure one of them didn't accidently get turned off
