crsundog
#1 Posted : 18 years ago
crsundog
I live in Costa Rica, Central America and I have a GE side by side. It is about 5years old. The freezer side is defrosating frequently but the refrigerator is working fine. Do I need a controller for the freezer side where the control selector switch is located or do I need something else? I have to purchase over the internet because parts availability down here is negligable. I don't want to buy something I can't use.
#2 Posted : 18 years ago
You need to supply more info. What temperature is the freezer at when it is working properly, When it starts defrosting, what else stops, Just the compressor or everything like the fans and compressor.
You might just have something simple wrong like a bad condensing fan in the back of the fridge, just check.
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 11 months ago
GE side by side turns on only when I disconnect J4 plug (Refrigerator & Freezer Repair)
by PandaTaco about a year ago
GE side by side water and ice not working (General Talk)
by Guest 3 years ago
GE Side by side fridge; control panel blank; not cooling (Refrigerator & Freezer Repair)
by peteror 3 years ago
GE side by side PSS26SGPA SS (Refrigerator & Freezer Repair)
GE side by side clicks once by compressor then once on board. (Refrigerator & Freezer Repair)
by Schaanman 3 years ago
GE side by side model GSS25KSTASS ice maker auger continues to run (Refrigerator & Freezer Repair)
by RodneyS 4 years ago
GE Side by Side Freezer 25 degrees warmer than set-point (Refrigerator & Freezer Repair)
by reese600 4 years ago
GE side by side starts and stops (Refrigerator & Freezer Repair)
by SethL 4 years ago
GE Side by Side - Water/Ice Dispense (Refrigerator & Freezer Repair)
by USS Pogy 4 years ago
GE Side by side GSHS6LGBBHSS (Refrigerator & Freezer Repair)
by Ksutherland 5 years ago
GE side by side refregator does not start (Refrigerator & Freezer Repair)
by patel_bhavesh100 6 years ago
GE side by side, uneven cooling (Refrigerator & Freezer Repair)
by GLMace 6 years ago
GE Side by Side Thermistor Locations (Refrigerator & Freezer Repair)
by AlkiRich 6 years ago
GE side by side, sporadic water and ice dispensing (Refrigerator & Freezer Repair)
by Ramski00 6 years ago
