kwong2385
#1 Posted : Tuesday, October 7, 2008 5:49:30 PM(UTC)
kwong2385
I have a GE refrigerator & Freezer with the model# of GSH22SGPC. Since the Defrost Heater from the Freezer side was burn out, I ordered a replacement. However, it did not work find because the replaced Heater required 100~120VAC, and I measured only ~30VAC from the Freezer end. Can some help me to figure out what might be the problem. Is ~30VAC from the Freezer end correct (from this model: GSH22SGPC)?
I really appreciate your help.
Thanks,
kwong
#2 Posted : Wednesday, October 8, 2008 12:16:46 PM(UTC)
Are you sure the refrigerator was in the defrost mode when you checked the voltage?
Did you check the defrost thermostat for continuity?
