lyne.roy@bell.ca
#1 Posted : Tuesday, October 7, 2008 12:36:00 PM(UTC)
lyne.roy@bell.ca
First, I would not recommend this diswasher to anyone. Bought it new not more than 6 yrs ago. Only after 2 yrs, the normal wash cycle would take more than 2 hours and a half instead of 1 hour and a half.
I had a technician over which told me that it was the heating element.
Secondly, the soap/rinse distributor is also malfunctioning. Rinse is all used in one wash.
And now, well, when I start the cycle, it makes a weird noise and then a burning smell seems to come out from the motor or water pump which is located under the dishwasher.
It seems that I should go and buy a new one although I used this bloody dishwasher 1 to 3 times a month. Would anyone know what could be the problem?
libertyappl
#2 Posted : Tuesday, October 7, 2008 1:01:48 PM(UTC)
libertyappl
Sounds like you have something down inside the pump (probably the impeller area) causing it to lock up.
Nat
lyne.roy@bell.ca
#3 Posted : Wednesday, October 8, 2008 5:26:25 AM(UTC)
lyne.roy@bell.ca
Should I change the pump? Unfortunately I live in Montreal Canada, a bit far to call for service :)
libertyappl
#4 Posted : Wednesday, October 8, 2008 7:49:40 AM(UTC)
libertyappl
I would start tearing into it see if you can see anything.
Nat
