I have GE Spacemaker XL1800 stopped heating. It is runnung, and the light is on and the turnable thing is turning. but no heat. What is the solution for this kind of problem. this is only 2 year old.
If it does not make any unusual noises then the problem most likely is a bad magnetron. If you need the right part number for the magnetron, post the complete model number of the microwave (inside the microwave, on the left side).
