2 Pages12>
brandinspector
#1 Posted : Friday, September 24, 2010 8:40:53 AM(UTC)
brandinspector
Does anybody have any idea how to fix a freezer that just hums when you plug it in?
Unplugged it for a day to defrost and move. Let it set for another day after moving and now it just hums when plugged in.
I can stop the humming when I rotate the temp control, so am guessing the thermostat is OK.
Is the compressor locked up?
Thanks.
#2 Posted : Friday, September 24, 2010 11:34:37 AM(UTC)
Very likely the problem is a bad start relay for the compressor.
- The start relay Part number: AP4367355
brandinspector
#3 Posted : Thursday, November 11, 2010 1:32:01 PM(UTC)
brandinspector
Thanks Gene.
I just got around to installing the part and things seem to be working. You're the man!
#4 Posted : Monday, November 15, 2010 6:21:20 PM(UTC)
You are welcome. I'm glad you were able to fix it.
lardman
#5 Posted : Monday, April 4, 2011 1:22:49 PM(UTC)
lardman
I too have a Gibson freezer (model GFU14F3AW0) that thawed an it emits a barely audible hum. As a comparison, I can hear my refrigerator/freezer whirring from 10 feet away, but my deep freezer could barely be heard unless I put my ear by the compressor. I read that I could be the timer stuck in defrost, but now I see the relay helped. Any ideas?
#6 Posted : Monday, April 4, 2011 2:07:16 PM(UTC)
Try to unplug the freezer for a day and post the results.
lardman
#7 Posted : Monday, April 4, 2011 4:36:26 PM(UTC)
lardman
Hi Gene,
Thanks for the quick reply. A few days ago, I think I saw (on another thread) that you posted the same suggestion. The freezer had been unplugged for about 3 days so I went ahead and plugged it back in. It still made the same low hum. Left it plugged in for a bit and went back, still the same. So I unplugged it and took out the relay, capacitor and timer.
#8 Posted : Monday, April 4, 2011 5:22:04 PM(UTC)
I don't think the timer is somehow connected to this problem. Check the capacitor for continuity and the compressor as described in one of our previous threads; http://forum.appliancepartspros...not-cool.html#post281680
If the compressor is good, replace the start relay.
- The start relay Part number: AP2113686
lardman
#9 Posted : Monday, April 4, 2011 5:54:00 PM(UTC)
lardman
I checked the compressor by checking continuity between the 3 prongs. I found approximately 4.5 ohms/6 ohms/10 ohms. The thread I was following said if the lower 2 added up to the highest 1 then the compressor was good. I'll check out the link you gave me to see if the method is the same.
lardman
#10 Posted : Sunday, April 10, 2011 9:59:35 AM(UTC)
lardman
Compressor
Based on my previous post, both the start and run compressor windings had continuity. I did the ground test between each compressor prong and a spot on the compressor where I sanded the paint off and I did not get a resistance reading on any prong...so I assume the compressor is not grounded.
Capacitor
I shorted the capacitor with a resistor and then checked it with an ohm meter and did not get a resistance reading across the capacitor.
So I take it this means I should get a relay.
Please confirm.
gibson freezer stopped working (Refrigerator & Freezer Repair)
by llutonhodges 2/28/2010 1:47:07 PM(UTC)
Gibson freezer will not shut off (Refrigerator & Freezer Repair)
by gjohndonna 7/20/2008 8:05:53 PM(UTC)
Gibson freezer door left open (Refrigerator & Freezer Repair)
by toddb 3/13/2008 4:26:50 AM(UTC)
2 Pages12>
