when drying the door keeps popping open. this is very random. there are times when it pops open quickly and other times it takes a while.
Please post your model number. Nat
If the door is not SPRUNG, replace the door catch, If the door is popping open because its SPRUNG, ajust it so it closes with no effort.
If this is a drop down door model,Lil trick I learned, use a wrench layed flat put it at the hinge and shut the door, crunching the wrench, and rebending the hinges, (most likely caused by either the kids crawling on it or laying the basket on it as you unload the washer).
