scrizz
#1 Posted : Monday, October 6, 2008 10:18:54 AM(UTC)
scrizz
when drying the door keeps popping open. this is very random. there are times when it pops open quickly and other times it takes a while.
libertyappl
#2 Posted : Monday, October 6, 2008 11:04:30 AM(UTC)
libertyappl
Please post your model number.
Nat
Drags1998
#3 Posted : Monday, October 6, 2008 3:02:47 PM(UTC)
Drags1998
If the door is not SPRUNG, replace the door catch, If the door is popping open because its SPRUNG, ajust it so it closes with no effort.
Zanshin
#4 Posted : Monday, October 6, 2008 5:29:51 PM(UTC)
Zanshin
If this is a drop down door model,Lil trick I learned, use a wrench layed flat put it at the hinge and shut the door, crunching the wrench, and rebending the hinges, (most likely caused by either the kids crawling on it or laying the basket on it as you unload the washer).
door keeps opening (Dishwasher Repair)
by marko 123 3/3/2010 9:25:07 AM(UTC)
