Replaced the PC Board and the LED lights are working fine, but the icemaker is still not working. How do I tell if something is frozen or the icemaker motor itself needs replacing as well. I manually added water to the icemaker to see if that would activate it and nothing.
if you replaced the emitter board and the i/m still wont cycle you could have a bad i/m thermostst or a bad module to test the thermostat you jumper from T to H and the i/m should start a cycle (if the emitter board is sending power to the i/m)
Originally Posted by: 4Duncan  Replaced the PC Board and the LED lights are working fine, but the icemaker is still not working. How do I tell if something is frozen or the icemaker motor itself needs replacing as well. I manually added water to the icemaker to see if that would activate it and nothing. Duncan, Which PC board did you replace ? When you open the freezer door, there is a panel on the right side wall, it has a red led light on it, is the switch in the ON position ? Is the red light on , off, or does it blink ? Let us know and we can direct you from there. :cool: :cool: :cool:
