4Duncan
#1 Posted : Thursday, September 23, 2010 10:05:51 AM(UTC)
4Duncan
Replaced the PC Board and the LED lights are working fine, but the icemaker is still not working. How do I tell if something is frozen or the icemaker motor itself needs replacing as well. I manually added water to the icemaker to see if that would activate it and nothing.
reliable bud
#2 Posted : Thursday, September 23, 2010 1:18:58 PM(UTC)
reliable bud
if you replaced the emitter board and the i/m still wont cycle you could have a bad i/m thermostst or a bad module to test the thermostat you jumper from T to H and the i/m should start a cycle (if the emitter board is sending power to the i/m)
Joe / APP Team
#3 Posted : Thursday, September 23, 2010 1:28:12 PM(UTC)
Joe / APP Team
Duncan,
Which PC board did you replace ?
When you open the freezer door, there is a panel on the right side wall, it has a red led light on it, is the switch in the ON position ?
Is the red light on , off, or does it blink ?
Let us know and we can direct you from there.
:cool: :cool: :cool:
