toolguy47
#1 Posted : Tuesday, September 21, 2010 5:58:40 PM(UTC)
toolguy47
I have a dryer that has begun to squeak. It also sounds like something may also be scraping. I took it apart and oiled the idler pulley. That seemed to help for a few days, but it has started again. Anything I might be missing? I read in other parts of the forum that the rear bearing sometimes goes bad. I wondered it that might be the problem. If so, I couldn't find the part in the schematic I looked up. I would appreciate any help that anyone could give me. Thanks in advance.
#2 Posted : Wednesday, September 22, 2010 2:48:53 AM(UTC)
Replacement parts for MAYTAG MDET336AYW Dryer - Ele | AppliancePartsPros.com
Your unit does not use a rear bearing.
The rear of the drum is supported by 2 rollers (Item 17 in Section 5).
They are a possible cause.
Spin the motor to see if it is the cause.
Since you also get scraping it could be the front glides are shot (Item 3 in Section 5)
Also since oiling the idler worked for a couple days, carefully inspect it for wear etc.
Electric dryer squeaking, squealing, and screaming. (Dryer Repair)
by Kurtzero 1/11/2018 4:26:56 PM(UTC)
Frigidaire Dryer squeaking (Dryer Repair)
by Gene.Dixon 9/22/2014 1:06:50 PM(UTC)
GE Harmony Dryer squeaking (Dryer Repair)
by kurtd 5/16/2014 4:34:32 AM(UTC)
GE gas Dryer Squeaking and now grinding (Dryer Repair)
by firefly 8/29/2012 8:31:09 PM(UTC)
Frigidaire Dryer Squeaking (Dryer Repair)
by rgrandmaison5@gmail.com 3/18/2012 6:19:24 PM(UTC)
by rherm52 3/11/2012 6:40:15 AM(UTC)
Dryer squeaking when spinning (Dryer Repair)
by Geno Altiery 11/25/2011 5:16:35 PM(UTC)
Maytag Dryer Squeaking and Timer Problem (Dryer Repair)
by Bob M 8/6/2011 11:08:23 AM(UTC)
Dryer Squeaking loudly (Dryer Repair)
by tculler 3/16/2011 4:51:02 PM(UTC)
Maytag Dryer Squeaking (Dryer Repair)
by mikecno 2/22/2011 7:31:17 AM(UTC)
by DOAinNY 7/6/2010 5:01:31 PM(UTC)
GE Electric Dryer Squeaking then not rotating (Dryer Repair)
by kenro 11/28/2009 6:27:03 AM(UTC)
Amana dryer squeaking (Dryer Repair)
by Barry Briggs 11/5/2009 9:30:37 AM(UTC)
Duet Dryer Squeaking (Dryer Repair)
by cdelonis 5/24/2009 10:19:11 AM(UTC)
Electric Dryer Squeaking (Dryer Repair)
by gander 1/29/2009 6:24:52 PM(UTC)
