Gas oven will not bake. all other functions work. It will broil and top burners work. It just does not heat up when bake touch button is pressed.
it could be the ignitor... test the gas valve with a ohmmeter.. Originally Posted by: reddog4me2  Gas oven will not bake. all other functions work. It will broil and top burners work. It just does not heat up when bake touch button is pressed.
The oven is a pilot-less oven. I cannot light it. So if it is the igniter I guess that is a part I can order and repleace easily. Anyone know where I can order an ignitor for a amana easy touch 700 gas range? TY
you can try to order one from sears, partsdirect.com
they have a really good warranty policy
Originally Posted by: reddog4me2  The oven is a pilot-less oven. I cannot light it. So if it is the igniter I guess that is a part I can order and repleace easily. Anyone know where I can order an ignitor for a amana easy touch 700 gas range? TY A complete model number will help us to help you.
I have a Amana range. model number agr5715qdq . I have located the oven ignitor and found part online for 32$. maytag wanted 101$. Before i buy it "how do i make sure this is problem"? Once again the oven does not bake when bake button presses on control panel. the broiler works and so does everything else like burners, etc.. Is this a good "guess" and just try replacing it? any tests to figure out problem? thank you all very much:)
i am in the same boat as you reddog.... im wondering the same thing
thanks for that.. explains a little bit about my whirlpool.. thanks!
