reddog4me2
#1 Posted : Tuesday, September 21, 2010 2:05:22 PM(UTC)
reddog4me2
Gas oven will not bake. all other functions work. It will broil and top burners work. It just does not heat up when bake touch button is pressed.
charvel52
#2 Posted : Tuesday, September 21, 2010 8:46:46 PM(UTC)
charvel52
it could be the ignitor... test the gas valve with a ohmmeter..
reddog4me2
#3 Posted : Wednesday, September 22, 2010 3:20:01 AM(UTC)
reddog4me2
The oven is a pilot-less oven. I cannot light it. So if it is the igniter I guess that is a part I can order and repleace easily. Anyone know where I can order an ignitor for a amana easy touch 700 gas range? TY
charvel52
#4 Posted : Wednesday, September 22, 2010 6:45:17 AM(UTC)
charvel52
you can try to order one from sears, partsdirect.com
they have a really good warranty policy
magician59
#5 Posted : Wednesday, September 22, 2010 7:45:34 AM(UTC)
magician59
A complete model number will help us to help you.
reddog4me2
#6 Posted : Saturday, October 2, 2010 10:25:11 AM(UTC)
reddog4me2
I have a Amana range. model number agr5715qdq . I have located the oven ignitor and found part online for 32$. maytag wanted 101$.
Before i buy it "how do i make sure this is problem"? Once again the oven does not bake when bake button presses on control panel. the broiler works and so does everything else like burners, etc..
Is this a good "guess" and just try replacing it? any tests to figure out problem?
thank you all very much:)
charvel52
#7 Posted : Saturday, October 2, 2010 10:35:41 AM(UTC)
charvel52
i am in the same boat as you reddog.... im wondering the same thing
reddog4me2
#8 Posted : Saturday, October 2, 2010 10:43:45 AM(UTC)
reddog4me2
http://www.appliance411.com/links/jump.cgi?ID=823
found this link on how and what to test. i am using the glow bar ignition section.
charvel52
#9 Posted : Monday, October 4, 2010 6:43:59 AM(UTC)
charvel52
thanks for that.. explains a little bit about my whirlpool.. thanks!
