KEITH HART
#1 Posted : Monday, September 20, 2010 3:43:06 PM(UTC)
KEITH HART
I've got a whirlpool duet dryer, it will turn on and give indicator control readings but won't start in any cycle....just beeps from the mother board. After reading other post, I have come to the conclusion that it is the dryer door latch having a problem sending message of being closed. I will replace that, but I also had the light bulb go out around the same time that this problem occurred. If I replace the latch do I have to replace the bulb, or can I just leave it out?
Joe / APP Team
#2 Posted : Tuesday, September 21, 2010 8:03:27 AM(UTC)
Joe / APP Team
Keith,
Sounds like a bad door switch, or at least the place to start.
You may not need the drum light , if the door switch is bad,
But, were it me I would order both, that way, you've got a spare.
We could have given you the part numbers,and circuit checks, if you had supplied a model number.
Good Luck,
:cool: :cool: :cool:
Whirlpool Duet dryer WGD9400 knob Removal (Washer Repair)
by Guest 1/1/2023 8:41:47 AM(UTC)
Duet dryer moister sensor (Washer Repair)
by Guest 4/29/2022 10:56:57 AM(UTC)
Whirlpool Duet Dryer Drum turning difficulty (Dryer Repair)
by DWMalcolm 2/6/2022 12:41:34 PM(UTC)
Whirlpool duet dryer issue (Dryer Repair)
by Wes13 12/15/2021 3:54:09 PM(UTC)
Duet Mod# GE9200LW1 Whirlpool Duet dryer (Dryer Repair)
by Guest 11/17/2021 6:59:07 PM(UTC)
Whirlpool duet dryer making clicking noise (Dryer Repair)
by Ctiong916 4/23/2021 9:00:11 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Whirlpool Duet Dryer - WED9200SQ0 - Thermal Fuse (Dryer Repair)
by cjmatthes 1/17/2020 2:09:48 PM(UTC)
WP Duet Dryer (GEW9250PL1) - chasing gremlins (Dryer Repair)
by JeromeGarcia 9/23/2019 4:29:12 AM(UTC)
Whirlpool Duet dryer - no heat (Dryer Repair)
by colino 3/19/2018 10:56:53 AM(UTC)
Whirpool duet Dryer (Dryer Repair)
by Louiella 1/23/2018 1:55:01 PM(UTC)
Whirlpool Duet Dryer Squeaks / Squeals (Dryer Repair)
by RickG375 1/5/2017 7:08:55 PM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 7:01:30 PM(UTC)
Whirlpool Duet Dryer Squeaks/Squeals At Start Up (Dryer Repair)
by damianr418 11/5/2016 6:53:54 PM(UTC)
Whirlpool Duet Dryer Grinding Sound (Dryer Repair)
by mintken 10/16/2016 8:31:42 AM(UTC)
