will i be able to replace the control panel on my oven if i order the part?
Originally Posted by: marcimessinger  will i be able to replace the control panel on my oven if i order the part? Marci, I would think you should be able to,all you need are basic tools, What's wrong ? Here are some insructions from a similar unit.
CAUTION:
When you work on the range, becareful when handling the sheet metal parts. Sharp edges may be present, and you can cut yourself if you are not careful. 1. Turn off the electrical power to the range. 2. Remove the knobs from the controls. 3. Unsnap the two clips at the inner control locations and lift the front edge of the control panel glass, (the two clips are located under the inner switch knobs)then slide the top edge of the glass out of the control panel flange, and remove it.And this should be the part you need. (click on number for information)Part number: AP3070862
Good Luck,:cool: :cool: :cool:
