marcimessinger
#1 Posted : Monday, September 20, 2010 3:36:42 PM(UTC)
marcimessinger
will i be able to replace the control panel on my oven if i order the part?
Joe / APP Team
#2 Posted : Tuesday, September 21, 2010 8:55:40 AM(UTC)
Joe / APP Team
Marci,
I would think you should be able to,all you need are basic tools,
What's wrong ?
Here are some insructions from a similar unit.
CAUTION:
When you work on the range, be
careful when handling the sheet metal parts.
Sharp edges may be present, and you can cut
yourself if you are not careful.
1. Turn off the electrical power to the range.
2. Remove the knobs from the controls.
3. Unsnap the two clips at the inner control
locations and lift the front edge of the
control panel glass,
(the two clips are located under the inner switch knobs)
then slide the top
edge of the glass out of the control panel
flange, and remove it.
And this should be the part you need.
(click on number for information)
Part number: AP3070862
Good Luck,
:cool: :cool: :cool:
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
Whirlpool Gold Accubake broiler element not heating (Oven Repair (including Ranges and Cooktops))
by quizandcook 3/9/2012 11:32:02 AM(UTC)
Whirlpool Gold Accubake Oven won't attain temperature (Oven Repair (including Ranges and Cooktops))
by sandy1951 1/7/2011 7:46:50 PM(UTC)
Whirlpool Gold Accubake w/ Convection (Oven Repair (including Ranges and Cooktops))
by Julie5118 9/19/2010 8:18:37 PM(UTC)
Whirlpool Gold Accubake Wall Oven - Sounds like a helicopter (Oven Repair (including Ranges and Cooktops))
by mszwarc5 2/15/2010 1:04:02 PM(UTC)
Whirlpool Gold Accubake oven error code E0 -F2- (Oven Repair (including Ranges and Cooktops))
by sajajea 9/25/2009 10:06:32 PM(UTC)
Whirlpool Gold Accubake temperature setting (Oven Repair (including Ranges and Cooktops))
by sforman1 4/22/2009 2:43:10 PM(UTC)
Whirlpool Gold Accubake Microwave (Microwave Repair)
by Roatan 11/8/2008 3:34:56 PM(UTC)
Whirlpool Gold Accubake door (Microwave Repair)
by helplessMICROman300 2/21/2008 4:07:59 PM(UTC)
Whirlpool Gold Accubake (Microwave Repair)
by TRENTGSTL 1/28/2008 10:29:52 AM(UTC)
