gonzalezf75
#1 Posted : Friday, October 3, 2008 8:51:08 AM(UTC)
gonzalezf75
i opened the front panel to look for a blown fuse but found nothing. the outlet works it was working fine but just quit. help please
libertyappl
#2 Posted : Friday, October 3, 2008 9:27:51 AM(UTC)
libertyappl
If your washer is less than a year old call Sears for service, so you don't void your warranty.
Nat
gonzalezf75
#3 Posted : Friday, October 3, 2008 10:06:59 AM(UTC)
gonzalezf75
thanks but yeah washer is more than 2 years old. any suggestions?:(
libertyappl
#4 Posted : Friday, October 3, 2008 10:08:03 AM(UTC)
libertyappl
Can you post your model number off the washer.
Nat
gonzalezf75
#5 Posted : Friday, October 3, 2008 10:17:54 AM(UTC)
gonzalezf75
the only thing i can find is (60 series) would that be it?
libertyappl
#6 Posted : Friday, October 3, 2008 10:23:25 AM(UTC)
libertyappl
If it's a top load washer raise the lid about 3/4 way up and look under the hinge area on the washer top, not the lid. If it's a front load open the door and it will be on the tag around the opening.
Nat
gonzalezf75
#7 Posted : Friday, October 3, 2008 11:20:28 AM(UTC)
gonzalezf75
ok is it 110?
libertyappl
#8 Posted : Friday, October 3, 2008 12:55:24 PM(UTC)
libertyappl
ok, that tells me it was made by Whirlpool....behind the 110 there should be 8 more numbers.
Nat
