i opened the front panel to look for a blown fuse but found nothing. the outlet works it was working fine but just quit. help please
If your washer is less than a year old call Sears for service, so you don't void your warranty. Nat
thanks but yeah washer is more than 2 years old. any suggestions?:(
Can you post your model number off the washer. Nat
the only thing i can find is (60 series) would that be it?
If it's a top load washer raise the lid about 3/4 way up and look under the hinge area on the washer top, not the lid. If it's a front load open the door and it will be on the tag around the opening. Nat
ok, that tells me it was made by Whirlpool....behind the 110 there should be 8 more numbers. Nat
