C.David
#1 Posted : Sunday, September 19, 2010 1:13:52 PM(UTC)
C.David
Would it be safe to bypass the defrost thermostat by connecting the two wires together with a wire nut??? I have parts ordered, should arrive in 2 to 5 days. Would be a temporary fix but I do not want to do if it is a dangerous remedy.
THANKS in advance.
C.David
magician59
#2 Posted : Sunday, September 19, 2010 7:36:52 PM(UTC)
magician59
The purpose of the defrost thermostat is to shut off the defrost heater at a certain temperature. Bypassing the tstat can cause a fire.
