Would it be safe to bypass the defrost thermostat by connecting the two wires together with a wire nut??? I have parts ordered, should arrive in 2 to 5 days. Would be a temporary fix but I do not want to do if it is a dangerous remedy. THANKS in advance. C.David
The purpose of the defrost thermostat is to shut off the defrost heater at a certain temperature. Bypassing the tstat can cause a fire.
