:confused: Help me;
Before we were married my wife bought this Kenmore 90 plus series washer model # 110.28942890. When we married and moved to where we are now there wasn’t much use for it, so it has been out in the garage for about 2 yrs. Now the washer that was here went we went and brought her washer in. I hooked it up and found out it leaks. I now have two problems.:confused: 1). I can’t figure out how the panel comes of for me to watch it while it goes though the cycle.
2). I have looked underneath it and it looks like it is leaking above the drain hose. There is a blue part with hoses come out of it, but I can’t see up there very well to tell were the leak is coming from.
Can any one help me????????
There should be 2 clips about 2 inches from the corners, between the top & front panel, use a putty knife or similar toll to release these clips. Then you can raise the top and remove the front panel to see what is going on. Without looking I am going to guess, since it was stored in the garage it's probably the pump had frozen and busted it. (should be part 3363394) I haven't looked at your breakdown yet, so this is a guess. I'll take a look and see what else I can. Let me know what you find. Nat
I'm sorry, but my washer doesn't have a front panel. It has a whole front and side panel.
Ok, on that model the cabinet should slide forward a little then tilt off. Nat
