leaper1950
#1 Posted : 15 years ago
leaper1950
Timed defrost not working - timer clock follows time of the day and makes the right "click" at 2.00am but instead of the normal "swishing" noise as the defrost starts - nothing. And the freezer just frosts up.
Can anyone please make a suggestion? :confused:
I am a motor mechanic but fridges are just not like cars!
#2 Posted : 15 years ago
Cannot find any tech info on this unit but it should not be that difficult to troubleshoot.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Here a couple good sites with fridge info.
http://www.applianceaid.com/frig.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 9 months ago
Control Board?? (Oven Repair (including Ranges and Cooktops))
by handywife1 about a year ago
Ice build up under meat drawer of my Kenmore Elite??? (Refrigerator & Freezer Repair)
by Guest 2 years ago
range burners and oven failed simultaneously???? (Oven Repair (including Ranges and Cooktops))
by barrot@bellsouth.net 2 years ago
Frigidaire Gallery ice maker sending water to water dispenser?? (Refrigerator & Freezer Repair)
by jonny comfort 2 years ago
Bosch AXXIS dryer - how to replace blower belt?? (Dryer Repair)
Amana fridge cabinet hole causes freezing??? (Refrigerator & Freezer Repair)
by Chris69 3 years ago
Any way to shorten defrost cycle on Frigidaire??? (Refrigerator & Freezer Repair)
by ColoradoRobert 3 years ago
Bosch 300 dishwasher - Middle spray arm only active for half-loads??? (Dishwasher Repair)
by Xcessiv 4 years ago
To repair or replace??? (Washer Repair)
by broomeju 4 years ago
What's WRONG with THIS FORUM??? (General Talk)
by Dave_D05 5 years ago
Whirlpool will not drain or cycle. No Obstructions. What next?? (Dishwasher Repair)
by RyGuy73 5 years ago
Whirlpool duet elec dryer diag code F70?? (Dryer Repair)
by cjmatthes 5 years ago
GE washer question ?? (Washer Repair)
by pjm333 5 years ago
Where does this deflector go?? (Refrigerator & Freezer Repair)
by sabretooth04 6 years ago
