marciag
#1 Posted : Wednesday, September 15, 2010 10:44:55 AM(UTC)
marciag
I received this part for my ice maker and I dont understand how to connect the quick-connect. It says to cut off the nut on the water line but then what. How do I connect the water line from the ice maker to the valve?
Joe / APP Team
#2 Posted : Wednesday, September 15, 2010 11:54:53 AM(UTC)
Joe / APP Team
Marcia,
Make sure the end of the tube is cut straight, and has no burrs or shavings on the end.
Press down or in on the gray plastic ring around the tube opening and insert the tube all the way in until it stops(1/2 inch or more).
Release the gray ring and tug outward on the tube,to insure that it is seated and locked in place.
Open water supply and check for leaks.
Good Luck,
marciag
#3 Posted : Wednesday, September 15, 2010 12:11:21 PM(UTC)
marciag
I dont see what gray ring I am supposed to press down on. Is is on the tubing that I cut the nut off of?
Joe / APP Team
#4 Posted : Wednesday, September 15, 2010 12:34:55 PM(UTC)
Joe / APP Team
Marcia,
No, the gray ring is not on the tubing,
The gray ring is part of the new fill valve, it is located on the opening for the tubing on the new fill valve.
Could you please send or attach the model number of your machine , and the part number you recieved,
So we can better direct you and varify you orderred and recieved the correct part number.
Thanks,
:cool: :cool: :cool:
marciag
#5 Posted : Wednesday, September 15, 2010 12:47:21 PM(UTC)
marciag
Thanks The part that I took off the refridge is 2182104 and the end I am asking about had male threads. The part I have says it is the replacement part but it doesn't have threads it is hard plastic. The part number I have is 2315576. Does that help?
Also, on the tube, I have not cut off the female nut, am I supposed to? I dont' want to cut it off to find out that I shouldn't have
Joe / APP Team
#6 Posted : Wednesday, September 15, 2010 1:59:26 PM(UTC)
Joe / APP Team
Marcia,
You are correct on everything you stated.
There will not be any male threads on the tubing inlets on the new valve.
They are now "Quick Connect , John Guess" fittings , that lock and seal the
tubing into the inlet opening when you install the tube.
Yes, you should cut the tubing off, just behind the plastic male nut,
As I mentioned before, cut it straight(angles will not allow the tube to seat and seal properly) clean the end of the tube(no burrs or shavings) and insert the tube into the matching connector on the new valve as deep as possible, and tug on the tube, to insure it is seated and locked in place.
PS
You new valve should look similar to this :
I mis spoke in my previous reply, I said "gray ring"
On this particular picture , the rings are Blue and Yellow.
I hope this is more helpfull.
UserPostedImage
marciag
#7 Posted : Thursday, September 16, 2010 2:32:51 AM(UTC)
marciag
I can't see the picture. Can you email it to me at Marcia.S.Grenier@irs.gov?
Marcia
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Water inlet valves burning out (Dishwasher Repair)
by Tydinelle 3/3/2024 4:06:06 PM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Whirlpool Water Inlet Valve Repair for Leak (Refrigerator & Freezer Repair)
by ForumUser1 12/23/2023 12:57:44 PM(UTC)
Water Inlet Valve WR57X10033 / AP3189335 for General Electric DTL18ICSRRBS (Refrigerator & Freezer Repair)
by breckrider 1/18/2023 7:43:17 PM(UTC)
Replaced water inlet valve, still no ice or water (Refrigerator & Freezer Repair)
by Guest 7/3/2021 3:14:08 PM(UTC)
dishwasher not filling with water...already changed water inlet valve (Dishwasher Repair)
by jbonez 5/25/2021 5:32:22 PM(UTC)
Leaky new water inlet valve on whirlpool gold refrigerator (Refrigerator & Freezer Repair)
by Guest 4/4/2021 5:35:03 PM(UTC)
Water Inlet Valve for Whirlpool WRF560SEYW05 (Refrigerator & Freezer Repair)
by nycgene 7/30/2020 10:50:55 AM(UTC)
Noise after water inlet valve replacement (Refrigerator & Freezer Repair)
by Kristsivia 11/3/2019 4:29:36 PM(UTC)
GE washer replace WH13X10057 water inlet valve (Washer Repair)
by Cmath 3/9/2017 9:23:21 AM(UTC)
Water inlet valve (Washer Repair)
by dcbradt 3/8/2017 4:02:37 AM(UTC)
Water inlet valve leaking (Washer Repair)
by Jimh64 1/29/2016 7:31:50 AM(UTC)
Hot to replace water inlet valve on GE washer dryer combo WSM2700HCWWW? (Washer Repair)
by AbbyBrickman 1/4/2016 8:36:24 PM(UTC)
