blaine
#1 Posted : Monday, September 29, 2008 1:29:54 PM(UTC)
blaine
freezer running but found ice build up inside freezer. frig. not cooling noticed a couple days ago clicking inside the frig. top under the cover
any advice
libertyappl
#2 Posted : Monday, September 29, 2008 2:21:02 PM(UTC)
libertyappl
Check your defrost system. and theair duct between the freezer & frig for ice buildup, sounds like a defrost problem.
Nat
blaine
#3 Posted : Tuesday, September 30, 2008 3:05:59 AM(UTC)
blaine
nat there was very little ice build up btween frig. & freezer cleaned it out but frig still to warm how do i go about checking defrost problems thanks
libertyappl
#4 Posted : Tuesday, September 30, 2008 10:01:28 AM(UTC)
libertyappl
Remove everything out of the freezer, locate the defrost thermostat above the evaporator coils, test with an ohm meter while it's cold. If it tests out it would have to be your defrost control. Use a hair dryer to melt all the ice and put it back together.
Go into the frig side and remove the cover on the control section, locate the adaptive defrost control, replace that and you should get you running correctly again.
Nat
Refrig not cooling but freezer is (Refrigerator & Freezer Repair)
by allofus00 11/13/2015 5:24:29 AM(UTC)
Frig not cooling at all (Refrigerator & Freezer Repair)
by jbill1918 7/16/2015 11:20:10 AM(UTC)
Hotpoint Frig not cooling, already replaced mainboard, heater and thermostat (Refrigerator & Freezer Repair)
by merc0230 8/27/2014 2:54:24 AM(UTC)
Refrig not cooling. (Refrigerator & Freezer Repair)
by jpskins 7/23/2014 4:24:01 PM(UTC)
Hotpoint frig not cooling (Refrigerator & Freezer Repair)
by merc0230 6/22/2013 10:56:45 AM(UTC)
Freezer and Frig not cooling (Refrigerator & Freezer Repair)
by frigadare 10/2/2012 7:58:47 AM(UTC)
Freezer & Frig not cooling (Refrigerator & Freezer Repair)
by missalive 9/17/2012 7:02:17 AM(UTC)
by dz1966 6/27/2012 12:58:42 PM(UTC)
Roper frig not cooling (Refrigerator & Freezer Repair)
by Charles Wilson 5/16/2012 5:08:30 PM(UTC)
Refrig not cooling and air comes from return? (Refrigerator & Freezer Repair)
by Cupdog 4/11/2012 2:54:28 PM(UTC)
Refrig not cooling (Refrigerator & Freezer Repair)
by jjpowe2 11/27/2011 6:23:41 AM(UTC)
Amana Frig not cooling, but freezer works (Refrigerator & Freezer Repair)
by drewbenson 10/13/2011 8:24:23 AM(UTC)
GE Profile side by side refrig not cooling (Refrigerator & Freezer Repair)
by j4son 9/22/2011 10:53:34 AM(UTC)
KitchenAid Superba Refrigerator Freezer & Frig not cooling (Refrigerator & Freezer Repair)
by dsmit10 9/3/2011 10:11:20 AM(UTC)
freezer and frig not cooling???? (Refrigerator & Freezer Repair)
by pmase123 7/23/2011 7:18:56 AM(UTC)
