Dryer is not producing any heat. Turns on, drum spins, nothing dries. Manual says check fuses. I can't find the fuses, but whatever. I check for continuity on the thermostats and there is one part that I don't know what I should get for a reading. Part no. AP2107358 Thermostat-heater. F-14 in the Motor/blower/belt diagram. Should I have continuity when I attach my leads to both wires. I currently do not have continuity there. Thank you in advance.
