:confused::confused::confused:
Originally Posted by: jersuz  :confused::confused::confused: Jersuz, Don't really understand your question,but The defrost thermostat and the defrost timer, are two separate components, and located in different areas of the machine. The thermostat is located on the evaporator, behind the back wall of the freezer. The defrost timer, is located in the control panel,or the compressor compartment, on the back of the unit. Hope this helps, Good Luck, :) :) :) Part number: AP3108453
