AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Gas Dryer still blowing heat - drum not turning
Gas dryer is still blowing heat, however drum is not turning... what could it be
Check to see if the belt is broken. Nat
The rollers, the idler, the drum slide, the belt, all need to be looked at.This one is easy to see if the belt is broken all you have to do is drop the bottom front flap.
Dryer Repair
