cathylyons
#1 Posted : Monday, September 29, 2008 6:23:07 AM(UTC)
cathylyons
Gas dryer is still blowing heat, however drum is not turning... what could it be
libertyappl
#2 Posted : Monday, September 29, 2008 8:17:42 AM(UTC)
libertyappl
Check to see if the belt is broken.
Nat
SublimeMasterJW
#3 Posted : Monday, September 29, 2008 11:56:37 AM(UTC)
SublimeMasterJW
The rollers, the idler, the drum slide, the belt, all need to be looked at.This one is easy to see if the belt is broken all you have to do is drop the bottom front flap.
