dterbeest
#1 Posted : Tuesday, September 14, 2010 1:26:58 PM(UTC)
dterbeest
My Whirlpool Thin Twin has developed a problem where in the middle of a cycle, the timer stops advancing. It does this no matter which cycle you choose, as far as I can tell. The dryer continues to run on high heat until you turn the timer dial to a stop position.
Do I need a new timer or is it something else?
#2 Posted : Tuesday, September 14, 2010 2:48:48 PM(UTC)
Sounds like the problem is a bad timer.
- The timer Part number: AP2976148
