pepchoo
#1 Posted : Sunday, September 28, 2008 10:26:44 AM(UTC)
pepchoo
HELP - my relatively new Whirpool slide-in convection range has developed a weird (albeit common) problem with the control panel. Firstly - everything on the panel works wit the exception of the "start" button which is fundamental in making the oven work. I have tried doing the ole' unplug-and-reset option with no luck except the display then shows "PF".
Csn anyone please help with further diagnosis or possible problem. Thanks in advance!
Zanshin
#2 Posted : Sunday, September 28, 2008 10:34:46 AM(UTC)
Zanshin
If all the other buttons work except one, I would assume you have a "touchpad" issue, some models don't have a seperate touchpad and main control unit, in that case it would require a new "clock assembly or main control board"
It is also possible if the touchpad is a seperate piece that the ribbon going to the main control is dirty or has become loose giving only partial connnection, check that first.
