yesod7
#1 Posted : Saturday, September 27, 2008 5:47:11 PM(UTC)
yesod7
Kenmore Elite, French door style, freezer below. Water dispenser is on INTERIOR left wall. Water stopped dispensing, ice maker stopped making ice; replaced filter, still nothing. No sound made when I press the switch for water, but it didn't really make a sound to begin with. Any ideas?:confused: :confused: :confused:
Correction: when I press the water button, I do hear a click from the area of the filter, as if a valve were opening and closing, but nothing was coming through. (One click on press, one on release.)
Zanshin
#2 Posted : Sunday, September 28, 2008 4:26:23 AM(UTC)
Zanshin
I can only assume you have checked your water supply line in the back of fridge, disconnect and run into a bucket, also make sure the fridge hasnt run over the line.
yesod7
#3 Posted : Sunday, September 28, 2008 7:41:44 AM(UTC)
yesod7
The supply line is good. When I changed the filter, it filled up with water. I took it off again to be sure, and you could feel that there was a pressure build-up as well as see all of the water that spilled out of the filter. It APPEARS that the ice maker is producing a small amount of ice, but that could also be my imagination.
Zanshin
#4 Posted : Sunday, September 28, 2008 10:16:01 AM(UTC)
Zanshin
If you have one , place a thermometer in the fridge compartment. Its supposed to stay within a range of 40 degrees plus or minus five, all the water for the chilled water and icemaker have to go through the filter, If its frozen, it won't worked right.
yesod7
#5 Posted : Sunday, September 28, 2008 4:29:29 PM(UTC)
yesod7
I think you were right. I couldn't get a hold of a thermometer, but I warmed things up a bit, and it works now. Whenever we put a lot of stuff in the fridge, some of it starts to freeze, and it gets colder in there. Thanks a lot for your help!:) :) :)
Guest (4)
