The refrig section of our side-by-side is below freezing. The damper door will not close when it should. We have changed the thermistor and the control board, but the door still stays open. I bought a new damper assembly from this site, but it is different from the original. In particular, the old damper motor has two wires ending in a female harness end, but the new motor just has two prongs within a shell, as if it needs a female harness end. So how do I attach the new motor? I believe I see how to shift the other wiring to the damper assembly (a ground, probably, for the motor, a two-wire plug, and a single-wire plug).
thanks for coming our site: nike,nike shoes,jordan shoes-www.nikeok.com , best quality and customer service here!be pleased to inform you,we just updated our site products online, and now you can place order and get a good deal with discount price online, below some changes for your informations;1. all items with reasonable prices, and easy to order.2, if you order over 120usd, all items will be free shipping.3, for above 200usd order, we hv a special gifts for every packages.our shipping service as following;a. payment: Paypal/western union/money gramb. shipping way: EMS,USPS,DHLc. shipping time: about 3-5daysd. deliver model: door deliveryyou can place order online, we will get your order details when you finish order online,thanks for your time!all the bestqingcustomer service rep. nike,nike shoes,jordan shoes-www.nikeok.com
The reply does not tell me how to connect the motor to the existing wiring. The original part has two wires (hardwired), with a plug to attach to the wiring harness. The replacement has only two prongs. Is there a short piece of wiring harness to connect those prongs to the existing harness? I can't believe I'm supposed to solder wires to the prongs.
