MaineAlan
#1 Posted : 14 years ago
MaineAlan
The refrig section of our side-by-side is below freezing. The damper door will not close when it should. We have changed the thermistor and the control board, but the door still stays open. I bought a new damper assembly from this site, but it is different from the original. In particular, the old damper motor has two wires ending in a female harness end, but the new motor just has two prongs within a shell, as if it needs a female harness end. So how do I attach the new motor? I believe I see how to shift the other wiring to the damper assembly (a ground, probably, for the motor, a two-wire plug, and a single-wire plug).
#2 Posted : 14 years ago
The damper control has the motor and the switch which should be connected according to the wiring diagram.
The wiring diagram is on the last page of the Tech sheet.
Here are the breakdown diagrams and Replacement parts for JENN-AIR JSD2695KES Ref - SXS/I&W | AppliancePartsPros.com
dgdl441
#3 Posted : 14 years ago
dgdl441
thanks for coming our site: nike,nike shoes,jordan shoes-www.nikeok.com , best quality and customer service here!be pleased to inform you,we just updated our site products online, and now you can place order and get a good deal with discount price online, below some changes for your informations;1. all items with reasonable prices, and easy to order.2, if you order over 120usd, all items will be free shipping.3, for above 200usd order, we hv a special gifts for every packages.our shipping service as following;a. payment: Paypal/western union/money gramb. shipping way: EMS,USPS,DHLc. shipping time: about 3-5daysd. deliver model: door deliveryyou can place order online, we will get your order details when you finish order online,thanks for your time!all the bestqingcustomer service rep.nike,nike shoes,jordan shoes-www.nikeok.com
MaineAlan
#4 Posted : 14 years ago
MaineAlan
The reply does not tell me how to connect the motor to the existing wiring. The original part has two wires (hardwired), with a plug to attach to the wiring harness. The replacement has only two prongs. Is there a short piece of wiring harness to connect those prongs to the existing harness? I can't believe I'm supposed to solder wires to the prongs.
