When my fridge was installed, the guy adjusted some kind of brake on the doors so that they opened only so far and didn't hit the wall or counter next to them. The doors don't stop anymore and I would like to prevent denting and scratching of the doors and walls. How do I make the adjustment that he did?
Thanks!!
Originally Posted by: josie2000  When my fridge was installed, the guy adjusted some kind of brake on the doors so that they opened only so far and didn't hit the wall or counter next to them. The doors don't stop anymore and I would like to prevent denting and scratching of the doors and walls. How do I make the adjustment that he did?
Thanks!! Josie, You probably should check in your Customer Use and Care Manual or Installation Manual that came with the machine. I can only imagine at this point, but you may have a loose or damaged door stop or hinge, the stop screw fell out, or something minor like that. :) :) :)
